- Aug 9, 2012
- 11,543
- Name
- sam miller
or better yet is it chimp friendly?
Go to the auction and see.What is the current bid up to
Don't hit door jams or HVAC vent covers. What I've noticed is straight on you can get close but at any angle you're asking for trouble. I get as close as I can without hitting it and cut it in with the wand. I want to flush that area as best I can because it needs it the most but I don't want to damage the transition.Does this one have crack able gears if you hit a door jam?
This isn't ebay........and ebay doesn't even work like that........But what would I know I have only sold a few things on ebay----$1,700,000+
Don't know...but it's safe to say bidding is still enabled after the time has expired so don't stop bidding until it won't take your bids.
Maybe Fred needs to synchronize the timer and "place bid"buttons to work together.
I'm not a cheapskate..... The only reason I did the dollar bid was the time constraints. I wanted to make sure I submitted the bid on time with the default increment already typed in. If I was gonna change the number I would have been late. According to the board counter. But that obviously didn't stop bidding when it expired...
I wasn't blaming you or Mikey but there is an issue with the "place bid" button accepting bids After the timer shows that it expired.
