1st choice restoration
What's ur procedure for drying crawl space under houses with just one place to crawl in located outside? The hole to crawl in is very small..
Fresh from outside. Caution, pulling in makeup air from the home can put out pilot lights and cause other issues.start pumping air in and pulling same or less amount of air out.
Ohh man you fooked those Mexican's over didn't you? No PPE either I bet. Wrong man you are sooo wrong!All of the labor was subbed to some really happy Mexicans.
Ohh man you fooked those Mexican's over didn't you? No PPE either I bet. Wrong man you are sooo wrong!![]()
When you're tired of Cowboy'n through it or if the job is critical to the point that there could be some litigation involved, I recommend a manometer be used.
The manometer read the neg air pressure in pascal scale and prints as proof that you maintained neg air pressure over a period of time. To be safe, I would not pull more than three pascals from the built environment.
We don't use it all the time but when you have a client that is overly concerned, its nice to be able to prove you had control of the air.
You better block out our name off the meter.![]()
That's a $600.00 meter but you can get a digital manometer off ebay for around $60.00.I'm gonna put a Chavez Patent sticker on it.
Naww I'd be more worried about the snakes, opossums, racoons.spiders an' cobwebs...uhhhhhhh!!!!!!!!
ohh and mouse turds too!
You da man!When you're tired of Cowboy'n through it or if the job is critical to the point that there could be some litigation involved, I recommend a manometer be used.
We did one years ago that we brought a couple of "helpers" for. they both started yelling ' NO SHOVEL THE CACA NO SHOVEL THE CACA" i said $25 an hour. they said "Me shovel the caca" and got to work.....It is a wild world out here in north Mexico.
Basically, it was here's 8k and then I sped away from the scene ASAP...
