Butler wont bring up RPM's in cold weather? See this video
Grand Rapids, MN
Had a bunch of calls with the cold weather today....
Had Butler's with the vacuum control pods that must have had some moisture in them....they would not allow the RPM's to come up....
And one of them, it wouldn't let the RPM's come down after cleaning.
Typically it is because the vacuum pods will get moisture in them over time, and just driving from a heated shop to 5 miles away, they can freeze up.
You need to move them by had if you can....or heat them with hair dryer or heat gun if in the field...
Or, can try some isopropyl alcohol or ws 40 in the hole of the pod and drain to see if can get the moisture out a bit but replacement is definatley needed.
They are not that expensive (was around $38 per pod last time I bought some)
Now the newer Butlers run off electronic control module....Much better!
Here is a video showing some locations of the pods and also what they look like and how to adjust them.
www.saigers.com
"Bring on the Blue!"
Reactions: Wing It
Grand Rapids, MN
Reactions: dgardner
Ann Arbor
Steve Lawrence
Never any trouble with the pods here in lower Michigan but I do like the electronic setting better--so steady and never goes out of adjustment.
Reactions: Mark Saiger
dgardner
Phoenix, AZ
Dan Gardner
Welcome to Mikeysboard Larry! I did a double take, as I have a friend named Larry Hanson!
When you have a chance head over to "How to become a supportive member and new member introductions" and tell us a little about yourself!
Grand Rapids, MN
Larry HensoReally t: 4342485 said:
Mark, here is the part number for your vacuum pods (they are choke pull-offs for older vehicles with a carb) hygrade part number CPA216.
Google the part #. There are some on eBay for $20 with free shipping. I would give you the link but it won't let me since I don't have 3 posts yet.
Thank you Larry
Really appreciate it and glad you are here.
Really look forward to hearing more about you and your helpful info
My brother has a unit that needs then pods
Gonna call him right now :)
Grand Rapids, MN
Can they be insulated? Like with a styrofoam spigot cover.
They actually don't need to be...and it wouldn't help.
They just start freezing up when the diaphragm inside starts to wear out and suck in moisture.
They will go a long time before needing replacement...and as you can see....can be pretty inexpensive. :)
