cdv filter box
Scott S.
Scott
I love this thing, it holds a ton of crap and I still get airflow.
Talking about filter boxes.
Does someone make them size to order?
I'm looking for a narrow one to be put permanently behind the passenger seat. Easily accessible from the side door. One with a simple lift cover.
I don't like the portable ones that drip and need to be taken out to connect to hose. Too bulky and messy for me.
Just a narrow box with a lift cover.
dgardner
Dan Gardner
Ofer what dimensions were you looking for? What inlet/outlet size?
No one's standard filter is close enough?
mirf
David Mirfin
Great filter box 2.5 inches one side and 2 two inches on the other. holds a lot and pretty easy to clean.
Johnshotheatexchanger makes them. Or at least did when John was alive. Check with them.
Gene
Reactions: ruff
Dan, not much space between the passenger seat and pro-1200.
About 6-7" Wide.
could be 10-17" H
and 12-17" Deep.
And a top cover lid and a lint basket so that I can easily pull the basket and remove lint.
Wonder if that can be done without much vac loss?
Tom McLaughlin
We've got a CDS Filter Box permanently mounted at the drain station in the shop to filter out debris, works like a charm for sure. It's very easy for the technicians to clean too.
gtech12v
Probably the prochem pre-filter box will work for you
Scott S.
Scott
I used my legend brand points for mine. So yeah I got it pretty much free. My customers love it, and I like being able to see all the crap I pull out, and I run 2-2" hoses to the box then one off of it, huge difference in suction.
Askal
Al
We have had 2 built out of aluminum. Would last 20 years easy. Cost 350 plus 150 for a filter basket that lifts out. Works great.
Reactions: dgardner
Who built them?
What dimensions?
2" out, 3" (I think) it is a Pro-1200, towards the recovery tank.
