New 1XP Cat Pump for Portables
MB Auctions
Building your own portable?
need a back up for your Dwell Pro or other Cat equipped portable?
Here is your chance to pick up a brand new Cat 1XP for a song. $590 retail/w FREE shipping to the lower 48 and the best deal possible if your name is Willy.
1XP075.03DC pump/motor assembly.
1XP — Raising the Bar on Quality Patented water-lubricated technology
• Designed to fit extractor space and footprint
• Supported by Cat Pumps industry leading customer service
• Off-the-shelf delivery
• Highest quality control means long life and hours of trouble-free service AC (Induction) Motor DC (Permanent Magnet) Motor Building on over 45 years of experience producing the best high-pressure water pumps on the market, the Engineers at Cat Pumps set out to design the best extractor pump available—bar none.
Customers were telling us three things: 1. Build a pump that lasts longer than the competition 2. Make the pump easy to retrofit into existing equipment 3. Come up with a design that will not leak and put contamination on the carpet or floor. No detail was overlooked to make the 1XP the best choice for extractor applications. A patented greaseless design and 100% sealed wet-end means no maintenance and zero leaks. Solid ceramic plungers do not score and wear like stainless steel plungers—so pump life is increased by a factor of 10 or more in some cases. The durability of the 1XP has attracted customers in other markets as well: electric truck mounts, misting, hydrostatic testing, and industrial washdown to list a few. When a well designed product like the 1XP comes on the market, customers find a way to put it to use. Customers who have upgraded their extractors to the 1XP have reported smoother and quieter operation, faster and more consistent priming, and greatly increased pump life. Maybe this is a good time for you to consider the 1XP from Cat Pumps?
Reactions: SCC
Spurlington
Spurlino
I would of removed the brass fitting from the swivel lines and attach to the pump after the pump was mounted .. this guy was spinning the pump to tighten .. almost need 3 hands when it comes down to the final tighten.
well OK, I'll remove the bid for $335 and sell it to you for $165.and pay the $35 to get it up to dealer's cost out of pocket.
