New 14" Swivel Ti Wand with Glide
Demoed at ICE to a very good response . . .
Very smooth ball-bearing swivel by Tom (DevPro) . . .
Milled Anodized Head eliminates middle pins and clogs . . .
Adjustable angle of Jets (#9502) . . .
Adjustable height of Jets
Lexan View Window for rinse results . . .
Short Slot Teflon Glide . . .
Cobb Assist Handle of course . . .
$749 limited time
I heard they had to hook it up to the Dwell Pro as it was the only machine there that could provide enough suction at the demo pavilion.
oh wait, I'm sorry, I'm confused..
Mytee would not let Dwell Pro set up there out of fear of being humiliated.
Where did this wand get tested?
Larry, you just posted this on Facebook but left out the ICE mention, why is that?
KevinL
Kevin Leach
can we get a pic of the top half?
Handle and valve that is.
KevinL
Kevin Leach
So what's so innovative about that handle? Just the way it's shaped? They're all adjustable so what's better about it?
It has 4 bolts and structural foam construction . . .
Mainly is taller and gives better leverage when scrubbing . . .
Jim Martin recommends them . . .
We have fit them to 1.75" and 2" wand tubes . . .
Erik
Erik
PLEASE, let everyone know this wand, as nice as it is, can not be used without a Glide. Many distributors would like the customer to find out the hard way.
I think a Green Glide will fit, as it is an exact replica of the 13.5" PC TI wand.
Not exact.
Look at the back of the head, no funnel chambers. Airflow will not be as good.
And if there are no metal lips, how would a Green Glide fit?
Erik
Erik
Your right about the air flow But the lips are the same.
Erik
Erik
It's made out of Aluminum!
I guess it could, just wouldn't last very long.
the angle and the way it sits on the wand make for a much better grip and when you push the wand it gives it a downward direction....that handle is a must for all wands...its light weight and takes away the heavy metal one....
as far as the glide...from what I understand Cobbs says that he has a short slot PTFE glide that fits that wand....PTFE is the same material that the glides on the Hoss are made out of....although I have not personally seen one...what I am hearing through the carpet cleaning grape vine is that the glide is much thinner then the green glides and not as strong.............????????????????????????
as far as the wand itself...I'm a westpac guy so I could not say....but I have heard from a few that it is a nice wand and does a good job....no other details about it.........
Reactions: TConway
