Hydramaster 421 pressure drops
lg2121
LG
When trigger is pulled pressure drops from 450psi to less than 200. Just had seals replaced less than 20 hrs ago an suggestions.
Thanks
Could be something stuck under the check valves in the pump or the regulator unloader is giving you problems
Is it Cavitating badly?
If yes check the inlet hoses for an air leak.
If cavitating a little, replace your check valves both sets.
doylebloss
Doyle Bloss
The pump puts out 3.5 GPM the primary orifice when new is the equivalent of a #2 jet, at that pressure it will flow .7 GPM; the recommended tool for that machine should be jetted equivalent to #4 and should flow 1.4 GPM. Check these two items and most times you find the problem; the primary orifice may not be properly seated or it could be worn, I have seen it accidentally get swapped with the secondary orifice which is the equivalent of a #6 jet which at the stated pressure will flow 2.1 GPM.
Marcus Van Wyck
Lead Technical Service Representative
HydraMaster/US Products Pro | Customer Care | 11015 47th Ave W. | Mukilteo | WA | 98275 | Customer Care: 800-426.1301 ext. 1633 | Fax: 425-771-7156
www.hydramaster.com | www.usproductspro.com
