A Day with the Saiger's! Zippers, Rotovax 360 XL new drive block....lots of stuff
Mark, Kirk Saiger and his son Bryce Saiger, and our other brother Dave Saiger.
Getting together on a Sunday to clean a 2 level restaurant in Walker, MN.
Testing of new products and tools...
and just having a fun time as we doing getting together :)
We are cleaning nerds!
Tested out the new Rotovac 360 XL drive Block and red pad for agitation (also had our little CRB)
Tested 4 different chems....and combos......lot's of flavors :)
Zee
You welcome for the spacer on the pad driver... :lol: I sacrificed a beige pad and the bottom of the XL shroud. (it melted a bit) That spacer was not part of the driver and the bristles barely stuck out longer than the housing... So as it spun around, it was touching- and the friction melted the shroud. (they suggested that we remove the shroud every time we want to use the pad driver... I said: that is not going to happen, it needs a spacer installed)
Kudos to RV!
They did ship out a replacement and the new pad driver already came with that inch extender.
Just to illustrate :
Now the bristles stick out an inch and are perfect for scrubbing. I'll get a picture tomorrow...
Reactions: Mark Saiger
Kudos to RV!
View attachment 1949 View attachment 1950
Thank you Zee!
No way I would have wanted to take off that shroud each time....
