Spot Cleaning
M
M.Doug
I have an extech pH meter that I would like to use to identify the spot prior to selecting a spotting solution. Should I identify the spot prior to cleaning or can I still get a proper reading after the initial cleaning?
J Scott W
Jeffrey Scott Warrington
Your normal cleaning routine will likely remove most spots without the need for any special treatment. Therefore you could spend a lot of time getting a pH reading on every spot prior to cleaning.
There are several ways that each help identify a spot / stain. pH is one of the ways. Using a pH meter on a particularly difficult to remove / identify stain can also be great marketing that sets your process and your business apart from others.
The presence of prespray or other cleaning agents will affect the pH. If you want to get a true pH reading after initial cleaning attempts, rinse out whatever else may be there beside the stain.
I agree with Scott.
Most all spots are removable with standard cleaning. Grease and oil spots will need some type of solvent or citrus solvent in order to be removed.
I wouldn't worry about a PH pen for general cleaning. I'd only use it on spots that are not removeable to help you assess what it is.
As much as you may think that a customer may appreciate a dog and pony show with lab coats, beekers, pH strips and pocket protectors and an explanation of their situation in Latin...
Most just want to hear "no problem"...
are you somewhat new to the biz, Mel?
if so, I think you're over thinking it
if not new to the biz, do you have a pocket microscope too?
