is there a better solvent spotter?
Luis Gomez
Luis Gomez
I like it but stop using it because the packaging sucked. I got tired of busted toothpaste tubes, I now use Vacaways Hell-gel.
Jim Nelson
Jim nelson
If i cant get it out with my wand,I use a dry solvent. Fels never removed one spot for me. 99%comes out with my wand the other 1% dry solvent. I think you all use way to much chemicals with poor results.
dgardner
Dan Gardner
Funny, I have (and have used) Power Gel, but have never used Pro Solve. If I don't win the raffle I will have to break down and order some......
Ron K
We never apply just solvent alone . Always a spray of Perky then dry solvent works for us.
Reactions: J Scott W
D Luke
Derek
Not a gel but Gumolene works great on tons of spots for me.
KevinD
Kevin Dumas
I've used Bane's Saf-T-Solv volatile solvent (liquid) for 25 years.
No other volatile solvent or gel has worked better for me. (Even Cobb's new one)
You would have to smuggle it into Cali though.
Prochem's Citrus Gel & Power Solvent
Vacaway's Hell gel
Pro's Choice Pro Solv Gel works excellent but I just don't over stock too many tubes or it dries up on me before they use it.
Reactions: Donwand
D Luke
Derek
Still pretty expensive at over $23 a pint compared to similar spotters, right? Not that it much matters, it's not like it gets used by the gallon.
Solvent clean and acetone 50/50 in an old rust remover bottle. Nice small stream. Agitate with fels naphtha
Gene
Reactions: Russ T.
