Mikey's Fest Pet Benefit Florida Prize List
Is that really a donation?
if so....I have some big mac coupons I don't need you can raffle off............
Ron @ Seal A Door has added a Screen version to their prize package.
Seal A Door kit TWO PACK, solid window version AND Seal A Door screen version $360
Dwell Pro Mike has donated two gift certificates to the auction.
$2000 off a DP2 and $1000 off a DP1!!
Environmentally Safe and Effective Carpet Cleaning Machines
Count on Dwell Pro in Aspen, Colorado, to provide you with environmentally friendly and high-quality surface and carpet cleaning machines. All of our machines have unsurpassed performance from Constant Flow Design (CFD) portable extraction units, and feature the following:
• 1,200 PSI Adjustable Pumps
• 2” or 1.5” Optional Inlets
• 2hp Motor Drives
• Detachable Hoses and Power Cords
• Dual 3-Stage VAC Motors• Easy-to-Open Inspection Plates
• Flat-Free Pneumatic Rear Wheels
• High-Strength Aluminum Extrusions
• Low-Profile Hose and Cord Storage Tank Designs
DWELL 1 Surface Cleaning Machine
This portable machine includes the following features:
• 2.5 Gallon-per-Minute Pump-out
• 50-Foot Housed Electric Cords and Water Hoses
• Built-in Electric Outlet for Running Rotary Tools
• 2 and 4 Wheel Mode
DWELL 2 Surface Cleaning Machine
This machine has been patented as number 8,485,203. Its features include:
• 100-Foot Housed Electric Cords and Water Hoses
• Built-in 50-Foot Metered Pre-Spray Gun• Tank Defoamer Valve
• 2 Wheel or 4 Wheel Position
Benefits
As our machines can be vertically stored inside vehicles, they prove to be user-friendly equipment. Additionally, our machine offers benefits including:
• Easier Operation
• Less Lifting• More Efficiency
Truck-Mount Versus Dwell Pro Machines
Unlike gas- and propane-operated truck mounts, our machines are equipped with enclosures and muters to suppress noise pollution that’s disruptive to humans and animals. Our machines use electricity in the dwelling and require less monitoring.
Truck-Mount Exhaust
Truck-mount exhaust worsens allergies, triggers asthma attacks, and contributes to heat-trapping gases that react in the atmosphere to produce smog, acid rain, and harm ozone. To prevent these issues, our machines utilize existing water heaters and electricity in the dwelling.
Dwell Pro Operation
Using truck-mounts means having dirty hoses on exterior paths and requiring open doors for access. In addition, truck-mount operators must monitor running gas motors and the security of the dwelling being cleaned. As our machines are located near the operator and in a secure environment at all times, they eliminate the need for a second operator and constant monitoring.
Contact us in Aspen, Colorado, to get more details on our eco-safe carpet cleaning machines.
Reactions: Erik
Easy Grip Handle
It’s an internal and an external valve! Only the jet side of the valve is exposed. The inlet side is inside the tube along with the solution hose!
  • Forged brass valve
  • Easy grip handle with no bulky solution line
  • Comes with a 6 ft., 1-1/4 inch HIDE-A-HOSE, high pressure
  • Comes with a stainless steel 1-1/2 inch vacuum hose joiner on the end so you can quickly attach vacuum line
  • Low pressures up to high pressures
  • Built in vacuum release
