- Oct 6, 2006
- 117,065
Getting packed up for Florida..
You should be able to loosen the clamp and turn it to the other side. Or do u want a modification?Hey erik, could I retrofit the vac hose hook up to my zipper. The hose coming off of the side on mine doesn't work for me.
The hose cuff gets in my way also needs to be lowered down the handle about 6 inches so I don't keep hitting it.Hey erik, could I retrofit the vac hose hook up to my zipper. The hose coming off of the side on mine doesn't work for me.
The same thing as a wand if your spraying and not moving. You could get that area wetter or sink a spot, that could wick up. Yes I said could!What happens if you don't keep it moving?
cough,cough, ball valve, hack, cough, coughI will be at Mikey's Fest and will stop by if you will be there.The newer vac tubes are 3" lower. Get ahold of me at the end of next week, I may have a fix for you.
I don't think it will replace the Zipper. You need to keep moving the tool, but it does clean good and fast.
Ralph...you know its there right but you keep hitting it?The hose cuff gets in my way also needs to be lowered down the handle about 6 inches so I don't keep hitting it.
How is the red Zipper solution line quick connect setup? My #4LG made the little black hose you sent me spring a leak.... Granted it was my fault, I was still getting used to the heater.... My temp gauge pegged at 250° at the Zipper jr... I'm currently using a 45° off the trigger valve, with a strainer and male q/c.... It works ok, but when I get to a wall on my left, it's an awkward angle I need to push at...
Maybe I need to 90° elbow down to another 90° elbow and go from there....
I have never turned around to use the side with the best clearance.....
