Travis Sonderegger
- Feb 20, 2015
- 198
- Name
- Travis Sonderegger
Question...
I have been putting pretty cold water into my portable and it isnt getting all that hot. This could be because it is a portable but probably also because of the temperature of the water going in. With the heaters in these things (I have the Ninja Warrior) does it have a thermostat where it will kick the heat off if it reaches a certain temp?
I have been reading a little on what I could find through the search, some people are saying that water too hot will damage my pump. Does the water go through my pump and then to the internal heater of the porty?
I would like to get a bucket heater and try warming my water up if you think that would help. If not, I will play with my chems a little more so I can find something that works well for me.
Thanks Everyone!!!
Thanks Everyone!!!
, had one vac motor need to be replaced. The only mod, I'd think about doing - getting an adjustable pump that goes to 300psi or so. Pretty sure mine is a pumptec.
