A TRAILER SETUP....REALLY OMG!!
Doug Cox
Delavan, WI
Doug Cox
So, I decide to buy an enclosed trailer for hauling shit around. Was at the car show looking at them and decided that a 7X14 was the size I wanted to pull with my Wrangler. Once I hooked that baby up I knew it was too big and downsized to a 6X12, but once I parked it in my driveway I realized this trailer is still huge. Its friggen 8' high, 8' wide and probably 16' in total length. I can't for the life of me know why any cleaner would want to have to maneuver one of these beasts around instead of a van on peoples property. I can't believe a 12' box would be sufficient or am I wrong?
Mrice
Fl
Mat
I have a 7x7x10 that works well but I run a Mytee ETM and cary no water or wastewater tank...It's awesome, I'm tall. If my tow vehicle ever goes or needs to be in the shop I can replace it on the fly. Same with my Vac set up.
Reactions: Art Kelley
I pull a 7x12 trailer "somewhat" regularly for the non CCing side of my biz.
and not bragging, but i can put a trailer anywhere it will fit
I also know I'd hate it as a CCing wagon..
I understand why some make that choice when starting out though.
They likely already have a tow vehicle (pick-up or SUV) so a trailer becomes a much less expensive option compared to a new or decent used low mileage van
.L.T.A.
Shawn Forsythe
A trailer size and construction type is a consideration best resolved AFTER you have a firm idea of your cargo. Cargo that can be loaded evenly and is modular, such that the tongue weight can be "tailored", permits the user to use a "tight" trailer close to the cube dimensions of the cargo.
However, when you are throwing a CC TM into the mix, the complication is multiplied. In an enclosed trailer, the TM must first be placed within specified zones that permit cooling air access and egress, while also sharing a space with large, heavy accessories such as a loaded hose reel(s), fresh water tank, etc. All of this while balancing the load for the aforementioned acceptable tongue weight. Dual axles give a measure of latitude, inasmuch as weight distribution is a tad less sensitive to the resultant balance.
I've seen a number of trailer installs that were less than ideal, because too small a trailer was used, leading to either poor cooling placement to get balance, or poor balance to achieve adequate air flow. Strategically placed vents, doors, fans can certainly help some of the cases. And for some, this is the route users take. Cooler climates can also help.
When I was ever in a position to make a recommendation, I advised the buyer to put together his anticipated cargo (TM, etc), then lay it out and deduce the size and style of the trailer that would be required.
Again, the OP does not specify what is being transported. If it is removable modular support "stuff", certainly a tight trailer fit can usually be accommodated. Especially where access aisles and/or other open space zones are also not required.
Doug Cox
Delavan, WI
Doug Cox
A 6X12 is 8 feet wide?
Really? You have to ask this DA question? Come close, Dan, I'll whisper the answer to you............... add the width of the fenders and you'll be pretty close to 8'.
Benton KY USA
Yeah with the tongue length included.
Driving Kentucky roads with a wide trailer is really a hassle. I have a utility trailer with a 5x8 box, seven ft wide track. Not quite so bad.
Barry-QDCC
Jurupa Valley, CA - So. Calif.
Barry Rhoads
I use a Ford ranger pulling a 5x8 enclosed trailer. I've done so for 6 years now. I really can take it anywhere and have never really been bothered by the fact I'm pulling a trailer around. While there are benefits to having your stuff in a trailer (like if your tow vehicle needs work you can pull it with another vehicle) in the long run I'm considering going back to some sort of van set up. It is a PITA sometimes to be using the trailer.
mirf
New jersey
David Mirfin
I have no interest in hauling a trailer other than for misc. equipment
Buck1955
Indianapolis
John
My advise is to not get one with a rubber roof, they will leak. I had a 7x14 v-nose that had a rubber roof, rotted out the studs on one side.
