Vinyl Partitions!!!!
Shane Deubell
Any ideas on how to clean vinyl partitions in an office?
They sound like the old vinyl records when you rub them.
Industrial environment with grease and fine machine dust.
Shane Deubell
Just spray and wipe with a towel. If you're real concerned you could use a damp towel to rinse but i don't think you'll need it. Good stuff, very economical. You may just start using it on your contract work too. :cool:
Thanks! :headbang:
Think we used simple green last time, only worked ok.
Renovate will kick the shit out of simple green. It will work faster and still not harm it.
Its an amazing product, our fire restoration tech's use it daily. 1.5 ounces in a 32 oz squirt bottle should be strong enough. If you wanted it stronger just add more Renovate but label the sprayer as a stronger mix.
Reactions: Shane Deubell
Shane Deubell
I hope....
Shane Deubell
Dam chavez, you really DO know everything :headbang:
Only took an hour and half this time after spending gawd knows how many hours last couple times.
Never thought about using a fire restoration product.
Atomic, just spray and wipe.
Thanks man :winky:
Thanks man :winky:
His head is almost as big as Lockhart's and Mikey's.............
