Tar spot on the carpet...
Jeremy N
It is just a 3x3" spot. I've got some POG and Cobbs Stain Solve.
Any suggestions?
towels. have plenty, that stuff is a mess.
Use a solvent spotter and work from the outside in.Keep blotting so you don't make it larger. Citrus gel solvents keep it from soaking the backing. Pog will help with any yellow staining. Rinse with solvent spotter and HWE.
San Francisco, CA
Delimonine (not sure about the spelling) works well on tar. So will most other solvents. Remove as much before solvent if possible.
Use the same precautions as with any solvent that can damage the backing.
If olefin, you may want to use another solvent as dilimo bonds with it.
Benton KY USA
WD 40. Agitate with the edge of the can.
As noted, LOTS of white towels should be kept on the truck for spots like these.
Jeremy N
Jeremy N
It's not a huge or thick spot. I'm gonna give it a try today.
Arizona
our summers are really hot and the asphalt gets soft and it can stick to the bottom of your shoe if they have done any type of crack sealing or repairs...so needless to say..summer time i am always running into this problem..I keep a case of all solve extreme at all times and always have a few on each truck.....
gets it out every times..........
Harry Myers
Charlotte, NC
Harry Myers
Here in NC I don't come across that. Yes asphalt tracking but not one spot of tar. Jim I agree with you. The oxidizer was not necessary. A solvent alone.
Harry Myers
Charlotte, NC
Harry Myers
Larry you do not see the difference in the hue. I know you are very knowledgeable but an oxidizer on a solvent to me is unnecessary.
Goomer
Bronx, New York
Frank Mendo
I think if it was tar there would be more tracking from the feet. Almost looks like marker
I agree.
It does not look like any of the tar I have come across.
Looks much too "thin" and uniformly spread to be tar, but none the less, glad it came out.
Spring brings the tar around here as the roofing season picks up.
Surprisingly EASY to clean if your not a total spazz and make more of a mess by spreading it.
I find the key to be to take your time with the primary towel BLOOTING phase and to GRADUALLY dissolve and transfer the majority of the solids to a towel before any direct "heavy"direct topical application of solvent is applied via spray or quirt.
Surprising how fast tar can dissolve with a good solvent, so gotta be careful not to liquefy too much at once and let it move deeper down.
My recent roofing tar adventure....................
