Heat Fail
S
Steamin McFadden
So I was forced to go to the van and get a solvent spotter, flippin heat failed me. I added $50 to the bill for the 20 second walk to the van .
Oh my gosh, the overspray on that wand is horrible!
It's a Mytee Bentree wand
can't run 'em much over 250 psi without overspray . ('least mine you couldn't no matter which "new improved" spaghetti tree manifold)
They're actually a pretty good cleaning wand ...but at 400+ TM psi, they splash jet spray ev'r whur sump'um awful
Reactions: hogjowl
S
Steamin McFadden
would be nice if they let someone who knew what they were doing design the jet manifold, , a friend gave me the wand, and I use it cause it fixed the pain I was getting in my wrist . a Pimped out Joe wand is on my list.
then you should continue to use it, Andy.
As i mentioned, it actually IS a good cleaning wand ...splash spray notwithstanding
if i did more carpet (we do very little these days) I'd use it as my "speed dry" wand .
You know, for those custys that have light soil/well maintained carpet where you don't need to throw fire hose flow and pressure washer psi at it.
(overkill is trendy around here)
Turn the psi down to 275-300, make the carpets fresh and beautiful again AND dry in no time
when I was on the truck everyday, i did just that..had/used two wands regularly
one set up for heavy flush/rinse and the lower flow jetted "dry wand" i ran at 300psi
R
renegade_cowboy
That Dang wand I got last year with the site tube is still going strong with zero problems.. my next wand will be the Devpro Swivel wand. My Bentley swivel wand is still working good.. though the swivel needs to be improved, same with the jet manifold, but it still gets used.
