Gates Predator Belts
Doug Cox
Doug Cox
As much as I love these belts, something has changed with them in the last year or two. They use to just crack when they were in need of replacing and I check them almost daily after a few months. Now they are just disintegrating just like the cogged belts which doesn't make me too happy, but they probably still last longer than BX belts.
Heat is a big factor in the life of belts . . .
Enclosed TM's are detrimental to belt life . . .
Some current TM designs have even been modified to give an acceptable belt lifetime . . .
Doug Cox
Doug Cox
At 30 bucks a change, I'm not gonna bitch too much.
D
dgardner
That's one of the things I really like about Sapphires' design - the positive air supply over the belts to improve their lifespan.
A
Able 1
I think I got like 2,000 hours on my last set.. Belts are no longer a problem for me.
I've only read on the 570 having the fan blow through the frame.... The 870 didn't have the fan/frame cooler.... Maybe I'm wrong.....?
D
dgardner
Looking at the manuals I think you're right. Wonder why? Maybe the 870 layout allows better natural airflow?
Not sure, but they made it a selling point for the 570.... I personally would rather have the 870...... More sucky sucky........... Yes, I have a small penis syndrome.........:shifty:
Reactions: dgardner
not sure about the 870 but i always supply my belts with their own air source courtesy of a radiator fan. since installing it I've never had a belt break. there is a chart i saw once that showed the temperature and life expectancy. it was pretty eye opening. when the belt temperature got above a certain number the life was cut in half. the hotter it got the shorter the life. it wasn't a very high number from what i remember.
gene
Doug Cox
Doug Cox
Unfortunately my belts are only about a half inch from the exhaust which is challenging. Wrapping probably helps a little bit, but I think I have to just accept the fact that regular changes are a fact of life. After all, its 30-45 minutes to swap them out. Pretty good for a Genesis.
Doug;
At 1/2 inch, you need a heat shield plus wrap.
Wrap a single layer of 2" fiberglass , and add a thin SS layer held on with hose clamps.
Larry I don't know the genesis but if they aren't stainless won't it cause them to rust. Doug even with fast belt changes it always seems to happen at the worst time. I hate changing them when the machine is hot.
Gene
Gene;
The exhaust system on every HX TM should be STAINLESS .
With 1/2" of clearance, belt life will be severely shortened.
A heat shield is the easiest solution.
