Solution Tanks
curious how aero tech fills their tanks. Are they using their fresh water pump or their high pressure pump. I assume they draw from the bottom with a screen instead of dropping a line in from the top. You could certainly tee in to fill it from the bottom so only one hole. Seems like a great way to do it.
Gene
No water box or transfer pump on an AT so the fill of the chem tank or tanks is from the pressure pump via needle valves
Ok. Thanks. I think I remember seeing a brass contraption with a bunch of valves.
Gene
