Sa!ger porn.............
T
tubad sosad
if you want to shoot low angle please include the site tube for watching dirty water go up. is that the normal speed of cleaning with zipper, if not can you show longer video with reg speed? what flow are you running now?
it looks like a 1/8 th inch hose on there. does anyone know what max flow is thru that? just think if you have 300 ft. of hose and the pressure drop that goes with all 1/4 inch hose run, and then flow gets choked down to a 1/8 in. hose. seems like big pressure drop which should decrease flow if i'm correct.
nice clean path by the way nate.
The description I put on youtube... Sorry it didn't show up here....
"Commercial heavily impacted soil from rolling chairs with no chair pads..... Cimex scrubbed, 500 PSI, 5x 9503 Jets (15 Flow), Water temp 225° +, #4 Sutorbilt vacuum blower, 50' 2.5" hose, 25' 2" hose, Airpath dried... Wet forward and back stroke, very little water left in carpet after dry pass!!!"
I have other video I can load... That was a slow pass my mom did.... They don't use chair pads and the carpet takes a beating... You can move a lot faster in not heavily impacted areas... I was just messing around with video.... I was only out 75' of vacuum and 125' of solution hose... Beats me on the pressure drop, it works for us.... I used to keep the pressure at 400psi but with 2.5" hose, it helps recover more water....
Reactions: dgardner
