Zipper wand technique video
Pretty much the same technique here. Behind all the furniture and put it back then clean the whole room with the flow on and then go back and vacuum. It really gets the water hot with that technique. I have two small Velcro straps that hold the vac and solution at 5' and 8' back.
Gene
It's a sure sign you don't always vacuum if you're having to recycle the same video.
