Todays chairs cleaning
realclean
Bossier City, LA
Jesse Lowe
I got the opportunity to clean about 150 chairs today.
I know several have had questions about how to do this and what the production rate is.
Now for my production rate I will start with, after everything is set up and with a helper to prespray for me, and these chairs were not dirty at all.
I was able to do 70 the first hour and it took longer for last 80 as I had stop to reload water and prespray.
encapman
St Petersburg, FL
Rick Gelinas
Here's a trick I've learned for commercial chairs (works on residential upholstery too). Pre-spraying and a quick rota brushing reallyspeeds up the process! Then a light quick rinse is optional (when an encap pre-spray is used). Makes cleaning LARGE jobs with hundreds of hairs fairly easy. I also like to have a couple of helpers. 1 person pre-sprays, 1 person brushes, and 1 person extracts. Then we rotate the 3 people. It keeps the muscles from cramping up too much.
We use Encap-Punch for the pre-spray.
http://www.excellent-supply.com/Rel...tion-Carpet-Cleaning-Products-Encap_p_69.html
And we use the Rota-Brush for the chairs.
http://www.excellent-supply.com/Rota-Drill-Brush-Attachment_p_15.html
Ann Arbor
Steve Lawrence
Rinsing is optional? Really?
PrimaDonna
Megatron
NorthEast, USA
MB
We use a makita car buffer with cimex pads to do chairs and stairs. Just did a huge job at a church. 75 year old pew cushions. Church may be on the visit list when the Pope comes to town in September. They are getting ready now. Ill post some photos and videos that John took doing that job.
Reactions: windycitysteam
That's awesome! But too much to do for one man, you'll kill yourself.
I'd invest in another hand tool and a splitter for the hose and solution. You should be able to run two tools with just about any TM.
Most TM's have too much power for a single tool anyway.
realclean
Bossier City, LA
Jesse Lowe
I was very tired after this job and I do have splitters for my lines, maybe next time I will divide and conquer.
Sh!t, I must be the slowest cleaner ever..... Even running a splitter we'd do 50-60 chairs an hour.... Granted it was high school music chairs... 300 had my mom and I hurting.... My friend would pre spray, line up and take away chairs.... Then we had 16,000sf of carpet to do also... :(
Reactions: Mark Saiger
Ann Arbor
Steve Lawrence
Nice way to treat your mom, LOL, just kidding! Moms need good jobs, too. (Assuming she's getting paid well.)
I've been teaching my guys the no rinse uph method.
Most encaps are fine
but for delicates I like Prochem's Fine Fabric Shampoo. Acid side, optical brighteners and a nice "I've been cleaned" scent..
We do wipe/towle down any contact areas though
Travis Sonderegger
Monticello Utah
Travis Sonderegger
Will someone post some links to some of the brushes and tools you are talking about? I wonder if I could ever talk the school into letting me clean the chairs in the auditorium. (Small School, like 350 students, 7-12 grade)
Thanks for the video Rick!
I think that's great for freshening up light soiled upholstery. Auditoriums would be a prime example.
We are working two contracts right now and one from a hospital and the other office chairs from a large corporation. Neither of those would fit well with encap cleaning.
encapman
St Petersburg, FL
Rick Gelinas
Agreed.
tubad sosad
west coast
joe mama
i think that is the wrong way to clean. all you are doing is pushing the dirt into the fabric not out of it. and a damp towel picks up dirt better than a dry towel. I wouldn't show that video to any one that i was trying to get work from. talk about hacking, hell if its so lightly soiled then put some flex ICE in a portable and do a super fast clean. don't need to stay in the 1970's with all the upholstery cleaning tools available for us today.
at least a von schrader machine vacuums up the foam, if you need to clean at least use a water bottle spray and a wet vac to "rinse" with. a little more money and you could use a small extractor with SS uphol tool and a rinse solution in the tank. encap prespray if you like but get the dirt out.
i think that is the wrong way to clean. all you are doing is pushing the dirt into the fabric not out of it. and a damp towel picks up dirt better than a dry towel. I wouldn't show that video to any one that i was trying to get work from. talk about hacking, hell if its so lightly soiled then put some flex rinse in a portable and do a super fast clean. don't need to stay in the 1970's with all the upholstery cleaning tools available for us today.
Why extract it if it's lightly soiled? Unless people sit on it butt naked, there clothes will "extract" some soil off........:lol:
encapman
St Petersburg, FL
Rick Gelinas
Some of the soil is wiped up with the final step. And as Nate correctly mentioned, the little bit of what's left will be removed via their clothes.
Of course at this point we can get all mushy about this and say it's not as clean as clean can be. And you know what, you'd be right. But there are situations where it is a practical approach to upholstery maintenance. Consider a couple of scenarios.
1. Some jobs have lightly soiled chairs and a light cleaning is adequate for their needs. Why bring a bulldozer when a shovel's all that's needed.
2. Many facilities only want to pay peanuts for upholstery cleaning (for whatever reason - budget constraints or they're just tightwads). And in that case this method makes sense too. Sometimes you have to cut the cloth to fit the garment (to borrow an old tailor's expression).
Keep in mind guys... Upholstery is flat. We're not dealing with plush carpet pile. We simply need to displace the soil that's on the surface of the chair. And that doesn't require a fire hydrant. :winky:
I agree those are the key points. Light soiling can effectively be cleaned that way. When it comes to appearance management even on a low budget they get a major improvement.
I like it for fabrics that can be problematic with drying issues, like color bleeding or browning. It looks good and the appearance is safely improved.
Heavier soiling or contamination I'd push much harder towards HWE but ultimately its their upholstery. We will give them our suggestions and let them make educated decisions.
