PC WAND VALVE
glenboy
GLEN
Trying to install replacement valve for wand....3 hours and im ready to scream...bottom O ring keeps moving...I cannot believe it's this complicated..everytime I reassemble it...the stroke is short and once I spray...it gets stuck....I've assembled this upside down and rite side up....im frazzled
glenboy
GLEN
No, nothing is missing...I ordered 2 and THEY are both the same the problem is is the bottom oring keep sliding out of place
You didn't over stretch it did you? that o-ring is a very tight fit. Did you use white grease on it for lubrication.
A
Able 1
it helps the piston move freely. You might try it and see if it helps. I have a diagram on my work PC . I can upload it tomorrow if you would like to see it. Is that split teflon ring on the piston?
A
Able 1
Make sure the flat side of the Tigger is pushing on the plunger..
A
Able 1
I think I saw every valve last winter when working for my disty.. Always tried to see how fast I could fix them (not one came back).. I like any valve that can get fix without removing it from the wand. "Feather touch" are my favorite.
A
Able 1
Yes, Westpak.. I have one brass,and two stainless. I don't prefer one over the other. What do you like about the brass over stainless?
A
Able 1
Never had one crack though I haven't been at it as long as you.. leaking jets drive me nuts.. More heat more problems!
How long would a cold water truckmount last?
How many cleaners are out there making people happy with their luke warm 150 pis Ninjas?
I bet with an RE and a bit more juice, most carpet would look just fine with cold water...
A
Able 1
Well, I'm thinking like 190 to 210 you might not have the problems these guys running 250 is a waste to me.
Guys with 150psi portables usually have to advertise more for my taste.. I wouldn't do that to my customers, or myself..:biggrin:
Heat has it's place and I like it! I personally will NEVER run a portable in my life EVER again!:hopeless:
glenboy
GLEN
upon removing nut...piston stays in place...is that from no lube?
glenboy
GLEN
OK its 4:45 AM and I am up trying to figure this stupid valve out...I am going to admit....I GOOFED....finally realized there's only 1rubber washer..I had 2 in there...Boy do I feel silly...although I've never even opened one of these valves...Thank you all for the help...I believe it fits just fine now
