How to remove dried candle wax from carpet
grampi
Is there anything I can put on this dried wax to liquefy it without damaging the carpet?
Hair dryer will melt it and you can absorb it into craft paper or a terry towel. Just watch the carpet so you don't scorch it. Scrape up any remaining and touch up with a solvent spotter.
Reactions: J Scott W
TimM
Ogden, Utah
Tim Magaw
I use craft paper and an old iron set on medium. Works good. Try to scrape up as much of the wax before you put heat to it.
San Francisco, CA
It depends.
The heat and paper works well on white candle wax. It will, however, set the dye of a colored wax.
In that case, some solvents will help release the hold of the wax onto the fibers. Combine with gentle agitation, cold water rinses and patience, and it will do the job. The left over grease from the wax can be removed with OMS.
Reactions: Shorty
grampi
I tried the hair dryer with some success, then I decided to pour boiling water on it and then suck it up with my carpet cleaner...that seemed to work pretty well...it did leave a slight stain that I can't seem to get out...all of the wax is out though...thanks for the help!
La La Land
a damp terry cloth has more "pulling " power than a dry one.....
as the moisture is pulled out by the medium hot iron the wax will be pulled (absorbed) better as well.....
i worry 'bout some of yous kids sometimes!
the kraft paper trick is crazi ..there hardly ANY absorption in thin azzed paper!
Reactions: KevinL
Ron K
Thank you Bob! I will try that next time.
San Francisco, CA
Sorry, Tom.
That was just teasing Zee.
I live in the Sierra foothills.
Just your average forest paradise:
Near this little dinky place:
Do come and visit.
Ron K
Any Main Street with no Traffic Light is a great place to live in my opinion!
La La Land
yes...they fillet the foreskin off wit a very sharp knife....
then suck on it till the blood stops flowing......
....and this has what to do with removing candle wax?
No.. NO ...DON'T tell me Bawb...I'm afraid you will come up with something that involves candle wax, religious ritual, and bloodshed that will creep me out....
La La Land
well Jim...i'm supposein' that since this ritual was done WAY before Edison invented the litebulb...there musta been candlewax involved.....SOMEHOW!!!
i'm aghast at the butchery that most young boys go through because of the parents ignorance...
