Red pads vs Fiberplus pads
Goomer
Frank Mendo
I'm looking for alternatives to red 3M type pads for general agitation.
Although cheap and readily available, red pads seem to loose their "bite" and thin out fairly quickly on bigger jobs.
I'm considering FiberPlus (and FP Max) as alternatives.
They claim 7000-10,000 sq feet per pad, but ill take that with a grain of salt, and would be satisfied with even half of that.
Any other non-absorbent agitation only pad options I should be considering?
Mike Draper
For my cimex ive run the pre-cut pads and I think they royally suck. I go down to the janitor store and purchase 175 pads and then cut them to size. Its a pia but They stay much more agressive throughout the cleaning and last 3x longer.
Reactions: AshleyMckendree
encapman
Rick Gelinas
Be careful with colored pads (especially red). Some bright colored pads (though not all) will leach color onto the carpet, leaving a nice shade of pad-color on the fiber. Unfortunately when that occurs there's no way to correct it. :(
encapman
Rick Gelinas
Hahaha looks like a new business opportunity!
The ideas we get here on Mikeysboard are priceless. :icon_razz:
I just ordered a case from Rick,asked for the ones Mike recommend.
Hope that's what I get.
Willy P
Willy P
Been there. done that. There's a reason they're called FLOOR pads and not CARPET pads,
encapman
Rick Gelinas
Just for the record. We don't have any brown pads. I'm not sure which ones Mike's referring to.
Rick, which pads? I'm fixing to order more of that delicious Releasit and might as well get a box for the elves to use with the 175.
Rick, call Jeremy and find those Osh Kosh pads.
My guys refuse to use anything else..
I've had great results with the 3M series 3300 white pad with hog hair, much better than std white. Just harder to get 8".
Hope the pads Rick sends work well, the next few weeks will be brutally busy and I hope to make things easier for the boys...and the truckmounts.
Lee K
LEE KRAUS
i have used the red label release it, and i have used the basic release it, i get the same results, and the basic is way cheaper! any thoughts?
Correct me if I'm wrong; I think the basic does not have florochemical added for stain resistance. It would clean, but not leave protectant behind.
The DS2 does a fine job and is our go-to, along with "HydrOx" for organic spots.
encapman
Rick Gelinas
Encap-Basic is a very solid encap performer. It cleans similar to Encap-Clean DS2. Encap-Clean DS2 has a little stronger concentration of raw ingredients in its formulation, and it contains Soileze protector. But if basic cleaning is what you're needing (moderate soil), or if tight budget constraints are a factor, then Encap-Basic is a good option. That's the thought behind the product "options".
