2.5 Difference From 2"
rwcarpet
Robert Hodge
I've takin' a hell of an ass whooping the last week or so since I upgraded the Thermalwave Vortec to a 2.5 hose. I most always use the Ti wand, which is Greenglide equipt with the slotted version. That wand now stays glued to the carpet on most tight naps, except for a heavy shag or Freize. I'm feeling it these 62 year old bones. Glad I got a young, tough helper. But I noticed that he has noticed the difference, but to proud to complain.
Oh, did I mention that it really gets the carpet dry? I'm not sure if I want a Zipper now.....
Russ T.
Russ Terhaar
I'm still looking for that 2.5" waste tank elbow. I think it was a PMF part but could be wrong. Anyone?
I've had 100' of 2.5 sitting in the shop for a month now...
Thanks!
Steve Lawrence
Thanks!
Why would you want to weld an elbow into your waste tank? A straight pipe will offer less resistance.
Russ T.
Russ Terhaar
N
Not looking to weld. There's a part that PMF (I think) makes. It looked like a 2.5 inch metal piece with a gentle bend in it. I think I'd like the bend, to help keep hoses off my machine.
Ray Burnfield
Ray Burnfield
We have Greenie 2.5 elbows.
$149.00 for the double and $119.00 for the single
Reactions: Mark Saiger
Russ T.
Russ Terhaar
That's it!
I'd be looking for the single, I think. How do they attach? I've got a Cleanco 47 with 2 2" currently.
Thanks Ray!
Shane T
Shane Tiegs
Typically the Greenie elbows are installed on the recovery tank lid. A 2.5" hole is cut and 4 small bolt holes are drilled through the lid to secure the elbow and gasket. I'm not familiar with Cleanco tanks but it may be possible to install the elbow on the side or end. Turn the elbow to suit your specific arrangement.
If you're fighting the wand that hard, you're doing yourself and your helper a dis-service.
With all the repetitious movements we all do, it is not a question of if but when will your body be damaged.
The most important tool you have is your body. Not taking good care of it (having to exert too much effort) is a big mistake, with possible dire consequences.
Even when the reward is reduction in drying time, not to mention the potential loss of bragging rights. :winky:
Reactions: Bob Savage
tubad sosad
joe mama
i tried a prochem quad with slots and a butler, really hard to push. RW get a hybrid or hole glide. you will get great cleaning and easier push. slots are for apt. guys who don't know what pre-vac means.
Reactions: rwcarpet
Steve Lawrence
N
You do know that you need a 2.5" nipple on your waste tank to get full suction from your 2.5" hose.
Russ T.
Russ Terhaar
Not sure what you mean.
I'll be going from waste tank to Devastator to wand. I use Flash cuffs but maybe something different between Devastator and waste tank?
Big Jim
James Milne
Russ, I have the same set up as you; and I thought about doing exactly what you want to do. Then I thought why make that modification if can get better backside draw without it. I decided instead to run 2 short sections of 2" (5 to 10 feet) from the vac tank to a devastator then out with the 2.5". This will allow greater flow (CFM) at the van side of the devastator than a single 2.5", and no tank modifications needed. To simplify things I'll leave the two sections of 2 inch hooked up. I'll use cool cuffs connections at the tank and vinyl cuffs (in case they hit the ground during set up) at the devastator on the van side. Then 2.5 male cool cuff off job side of the devastator. Just the option that seemed to make sense to me.
Russ T.
Russ Terhaar
You might be right Jim, thanks!
I thought I read that 1, 2.5" hose allowed more air through it than 2, 2" hoses. That doesn't sound right though.
Jim, did you have to modify an existing Devastator?
jwfoulk12
Justin Foulk
Mine is set up kinda like Jim said, I have two 2 inch hoses about 8 feet long coming off my filter box at the back of the van. They run up and attach to a Y near my hose real and then I come off of that with 2.5 inch. But i like the idea of two 2 inch into a devastator then coming out with 2.5.
Big Jim
James Milne
No this is an original setup
Reactions: Russ T.
I've told Russ the same thing in another thread......... "You can lead a horse to water..................." :lol:
Reactions: Russ T.
Big Jim
James Milne
I probably got the idea from you Nate. I like the idea of stronger CFM between the Van and a restriction/choke point (Dev filter)
rwcarpet
Robert Hodge
Thanks!
Russ....call Lisa at Greenglides.She'll give you a number to call of a dealer who might have some.
rwcarpet
Robert Hodge
Well, there you go. Ray has some in stock, and not a bad price!
CMS in Northern Cali. And those look like smooth flow elbows, which is what you want if you are using an elbow.
