CanadianRuss
- Jul 27, 2015
- 265
- Name
- Russ Teskey
I'm sure there are times that you are not a dik....BUTTTT I'm just not sure when that is.Are you related to Donald Becker?
If you ever become aware of a time, don't wake me up!I'm sure there are times that you are not a dik....BUTTTT I'm just not sure when that is.![]()
I think you're probably a dik to people in your dreams too!If you ever become aware of a time, don't wake me up!
Dikk?Or do Mexicans just not know how to spell it?
What type of equipment did you use prior to your Cleanco Russ?
High pressure portable ninja and low moisture 175 machines
Back in the day I cleaned all the Denny's in the Milwaukee area. I haven't eaten at one since the first day I cleaned one. Not to pick on Denny's cuz I don't think there are many clean kitchens.No wonder you enjoyed cleaning that restaurant. High pressure portables can do surprisingly good work, but nothing cuts food grease like heat.
Back in ancient history when I was traveling showing truck mounts to cleaners who had never seen or heard of such a thing, I did all I could to make sure they would set up a demonstration at a restaurant. Nothing showed what a truck mount could do better than that.
It was also very good for my health. Each time I did a demonstration in a restaurant and had to hook my water up in the kitchen (no fresh water tanks in those "old days"), I got grossed out by the filth and grease and learned to pack my own food or eat at home.
No Zipper. Still thinking about oneWhat, no zipper....
Nice set up!
Is it possible to stop your hydro force from dripping?
I agree. Thanks for the tipMy experience seems the older the gun the leakier they get, replacing it with a new one will help. I've got an old one that I drain after the last area on the job is presprayed. Disconnect the solution line, keep the gun triggered and use a flat area on the gun to depress the nipple on the male qd, its amazing how much fluid will leak out, better on the uncleaned carpet than in the back of the van.
