Never. 100psi? "I piss harder than that!"Honestly, when's the last time you put brass fitting on a 100 psi Flowjet pump??
the friggin head of the pump is PLASTIC
300 psi @70 deg.F hose.
I heard of those machines that use recycled water to clean. Didn't know thats what they meant.....Never. 100psi? "I piss harder than that!"![]()
Wow Rick that's awesome of you to offer such a great deal!![]()
Ken,I have a strange thing happening,
When the edic is off the solution keeps dripping out, not a little a good amount. I checked it and it's coming from the nozzle. Any suggestion why?
EDIC" data-source="post: 4377050" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Five I did not see the check valve,Ken,
Which machine? The Polaris utilizes a solenoid to relieve or stop pump pressure, if it is stuck open due to contamination, it may allow whatever water is after the pump's "out" to leak out.
The Fivestars don't have this but instead use a check valve to stop water from draining when not in use. Typically a leak will occur if that check valve is missing (early models) or stuck open due to debris.
Wow niceyou can fix it for good for $2500
http://www.discountcleaningproducts....HR&gpla=pla&gclid=CJv0r-H-occCFQuQaQodVjgCUg
Wow nice
500 psi
EDIC" data-source="post: 4377559" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">View attachment 5747
If you don't have a check valve in either location, then you can order a 12132A check valve retro fit kit.
Hope this helps!
