Carbonated Solutions......
It has been good the times I've used it. I need to experiment with it more, but I only use low moisture on commercial and I habitually pull out the Cimex every time.
All I have are six loopy cotton bonnets that I bought from Plus Mfg. 20 something years ago. They shed like a dog and cause the rotary to bounce like a roller coaster if not centered exactly.
One day I'm going to get around to calling Bonnet Pro and get some good pads and try the CS stuff on a nasty rental.
Rieta Ebberts
The 100% cotton "mop yarn" bonnets are the ones I assume you are talking about? They DO shed a lot! We prefer the mop yarn bonnets with our product but we prefer the poly/rayon blend for that reason (shedding). They also seem to last longer than the cotton ones. Ideally, we wash, spin dry and stack them damp - don't put them in the dryer! The reason is that a damp bonnet will absorb much more than a dry one (think sponges on your counter - they don't work until you dampen them).
Reactions: hogjowl
J Brown
Jeff Brown
Directmopsales has some microfiber mop yarn style bonnets that I have been impressed with I think they remove more soil and moisture than the synthetic bonnets.
I also like the terry cotton style the best, Clark (Orbitec) use to and may still have some thick terry cotton pads that I think were the best pad for a rotary to remove soil and moisture.
They sell carpet bonnets too, cheapest place I've found.
Striped tuways are my fave.
Hey what's the big deal about this carbonated crap? Bridgepoint sells their version called "Clean Free" for $33 a 6 pounder. All it looks to be is "water softner and peroxide"
Rieta Ebberts
The FIZZ is from the peroxide.................DUH!
Bridgepoint's product is NOT the same composition as ours. Because it is not the same composition, it works differently as well. C'mon, Jimmy! If one chemical is the same as another, then this is a way over-saturated market!
I think I need a sample bottle of this stuff
How much is a gallon and what is the dilution?
Rieta Ebberts
It comes in pre-packaged powder form. We can send a one gallon packet, a four gallon packet, or a five gallon packet. Each packet goes into 1, 4, or 5 gallons of water to make ready-to-use cleaner. A full case of our product makes 100 gallons of ready-to-use cleaner. Just PM your preference and your address and we'll get it right out to you. Thanks!
You need to put mixing instructions on the packets. It's hard to keep up with the sheet of paper that comes in the box.
