- Oct 6, 2006
- 117,207
Is that the Ken Harris gizmo?
Its like saying you can do a fine job of carpet cleaning with a Rug Doctor. Yes you can use it and it does clean but its not ideal.It does not do a thorough job, I can tell you that first hand.
LOL I do!I don't judge
Does anyone do cleaning of air ducts with a porty? It is something I have been asked about a few times, and I've been trying to find out more information about it.
Imo.... Unless you are dominating your local area with carpet cleaning, I would not add another service til my bread and butter service(carpet, upholstery, etc) has taken off.
Yes. We have been cleaning air ducts since 2004.Anyone here who has experience with air duct cleaning companies?
That's a Ken Harris bullshit thing. I had one, it was awful . By a used rotobrush for $2,000 or go with a push pull system. Check laws as some states require a Hvac license to cut a hole in the line. Also many people don't want you CUTTING A HOLE. If you do, install a nice door port, don't do a tape and run.We have lots of customers doing a good job with this turbine-powered brush system and Dual Vac Portables. Your portable should have 200 CFM or so right at the source of this brush rotation.
It vacuums a few inches from the agitation.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=72&products_id=2545
I think the HydroForce electric brush system will also do a good job if the tech is through.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=70&products_id=1440
The bottomline, knowing what I now know, air duct cleaning was a horrible idea.
Ultrasonic blind cleaning is a pita. You either need a shop or a box truck with the unit mounted inside. You have to be able to dry them sufficiently to rehang if doing on location. If doing in a shop, you have to do a large volume to make it worthwhile. Ceiling cleaning though is like liquid gold for some. spray & run describes accurately.I think ultrasonic blind cleaning and drop ceiling spray 'n run cleaning is way to go for add on services ......
Ultrasonic blind tanks are a hefty investment for start-up, sideline work. We dropped blind cleaning, just not enough profit for the hassle. Too many jobs cancel when you explain you can't fix the paint damage caused by them squirting the blinds with Windex.I think ultrasonic blind cleaning and drop ceiling spray 'n run cleaning is way to go for add on services ......
Spray and run with disinfectant is the way to gospray & run
Hopefully you can outrun the lawsuits right behind you.Spray and run with disinfectant is the way to go![]()
I guess there should be a sarcastic icon![]()
