Boost-All??
steamron
Ron
I was wondering if anyone has used the new version of Boost-All with Bio-Break or Power Burst.
I'm doing a bar\restaurant and looking to kick it up a bit so the job goes a little faster.
Thanks
Wing It
John Wingfield
I've used it with grease eraser. I'm not sure if it makes a difference but it definitely didn't hurt. Just know you only have an hour once mixed to put it down.
haven't tried it.
I'm cheap, i use Oxyclean when i need/want a sodium perc boost
but what are you mixing the Power Burst at?
Bump it to two heaping scoops pr gal of hot water
I use liquid 40 vol peroxide if I want to bump it up.
But yeah that powdered stuff should work.
A
Able 1
Volume 89 for me..
BAM! would think that would be kind of dangerous to use?
Are there coffee spills? Sure, Peroxide is great. If not I don't think 02 does much for restaurants (Like Larry, we use Oxyclean)
Or lots of grease and build up?
Boost you prespray with liquid de'limilene, not powder. Dehydrated solvents just dint have the same kick.. Scrub with a red pad and enjoy..( love Chemspec Biosolve)
steamron
Ron
I did not want to mess with this to much, so I took my Hydro-Force sprayer and add 8 scoops of Powerbusrt to a half gallon of hot water and added about 8ozs. of Citrus-Solv (maybe a touch more).
I did let the TM heat up a bit then pre-spayed the hell out of the bad areas and gave the rest a good spray. When the Apex was ready I turned the psi up to a little over 500 and that did it.
One of there cleaning staff saw an area I did where the carpet meets the tile by the bar and said "DAM, that is awesome"
To be honest, sometimes I ask stupid questions when I know what I am doing, just looking for any new ideas to make it easier.
