- Oct 6, 2006
- 117,380
We used the 10" brush pro first to pull out two fist sized wads of pet hair from to 8x10s and our MBR.
Pre sprayed with Procyon Extreme (no odor and got some yellow spots out of an Olefin rug, rinsed well with tap water.
Setting up the CFX was frustrating for this first timer. Its a two cord system with a pump out but no pressure pump. I figured any 20 amp outlet with a GFI button would work. Nope, I had to go to the garage where the HVAC gets plugged into for the pump and vac switch and to the outlet in our laundry room for the one pump. I was tripping switched with out even turning the power on....wtf?
Once I got it up and running I found it to be well balanced set up. Hot tap pressure, two 3 stage vacs and the 360i, it did a very nice job and it feels as dry if not dryer then a truckmount. The water being fed to the toiled was impressively brown.
I spotted some uph and the Sheardry worked real well at house pressure and had plenty of vacuum to clean just about anything.
Now if I had to plug in the 1200 psi Ranger base AND the EDIC heater I don't what thee hell I would have done.
Tarps and corner guards were needed for all those hoses and cords...lordy.
