JIMMY'S SECTION 8 "PARTY MIX" PRESPRAY COMBO
Now this isn't Mark Saigers prissy watered down with plain labeled chems mix. Besides he only cleans for a 99% white demographic. He doesn't get those calls to go into those areas where you better pack a gun or knife. You know those jobs that you never tell other carpet cleaners about. The kind where you hope nobody sees you. You dress down into ghetto shorts and wife beater tee shirts. And when you pull up to those jobs you pray to God that you come out alive and your truck hasn't been vandalized. The kind as soon as you open the door to the place the STANK is so bad you can taste it in your mouth. The place so filthy that you can't wait to get home and shower.
I've been making this mix in a two gallon container for the past year to put into my HydroBLOWERforce. BLOW out the whole place with it.
Here is my recipe for the two gallon container that you mix up and pour into the Hydroforce.
1 cup of POWERBURST by prochem
1 cup of EXTREME by CTI
1 cup of VIPER VENOM tile and grout cleaner
1/2 cup of CITRUS SOLVE by bridgepoint.
And you can also add a 1-2 cups of 40 volume peroxide
But only stir and not shaken.
My HydroBLOWERforce has no metering tip .
And with this recipe you can also double up on the measurements as per water conditions .
Of course you southerners clean these #### holes everyday as those "Marties" are a different breed down ...........there.
Flex and 1 cup of real 35% per gal. Only two products needed. Cleans tile and grout also. I hate caring a bunch of products.
Gene
Reactions: Total_Rookie
I thought it fixed it.
Besides, with those ingredients, Jimmy only needs one mention of Allah, in any of his internet comments. To trigger a visit to his village, from homeland security :winky:
Good to know.
Is there a powdered version?
Ivan gave me a gallon of liquid in Vegas to take home..
Yes. Bridgepoint makes Flex w/citrusolve in a powder.
think he was referring to Procion, Tony
I'm surprised Jimmy's nuclear cocktail didn't include a scoop or two of Draino (LYE)
honestly though, if a double to triple dose of Flex or Powerburst (three heaping scoops from a tilted container) pr gal of hot water and applied RTU at a gal pr 125-150 sf doesn't get it, the carpet needs put out to the curb ..not cleaned
if you MORONS would actually take the time to try an electric sprayer with ACCURATELY mixed/diluted chems and compare it to that POS HF you've been using, you'll find chems work a LOT better
We just don't have situation where our chems dont "Work".
We use Cobbs powermax for all regular to bad ones and flex for he real greasy ones. We also usually mix up the chems and half of recommended strength.
We are not shy with the prespray and rinse very well with 600-750 psi with good heat and dry strokes.
Now that I think about this, this is pretty close to rocket science, calling nasa to see if they need help with anything.
Reactions: Bruce Humphrey
.............if you MORONS would actually take the time to try an electric sprayer with ACCURATELY mixed/diluted chems and compare it to that POS HF you've been using, you'll find chems work a LOT better
The Hydroforce been working spectacularly for us Morons for the last 26 years.
I am painfully aware that it is still considered the latest invention for some, (particularly in the great vicinity of WhoopChuck) therefore - "suspect" technology. But isn't electricity too?
Screw it, I am just going to start using floor stripper boosted with oxy clean as my prespray.
But I will use only a pump up sprayer, I promise.
I am certain it will clean like no other, I just have to use the premium no rinse stripper found on isle 4 on the left side.
Reactions: Mike Pailliotet
Costco doesn't sell stripper, SAMs does and that is called rinse over and over and over stripper.
You need to come to Vegas, I heard there are memberships you can join to Lear all about them
I have enough problems already thank you very much! Although I'm sure I could get you in a bit of trouble there. maybe I should go! :twisted:
How about Hotlanta? :biggrin:
