Delivery room pics of my new baby!
:eekk:
Actually mine are calloused from yard work but it doesn't seem to help. Ouchhhh! :biggrin:
This whole time @dealtimeman told me you had a Mexican landscaper.......I didn't know it was you......
I seen an sign on the side of the road saying "Need Jesus?" So I called it and a Mexican named Jesus showed up to my door with a lawnmower......:dejection:
:errf:
Yep its me alright.
I love it!!! :headbang:
Too late to get you help, you're a lost cause! You and your brother Lockhart!!! :biggrin:
Reactions: Nate The Great
Grand Rapids, MN
Butler runs an after market Solid mount (Rigid) Flex fan on the front that is also just milled off at the bolt mounts to sit back about a quarter of an inch....
BUT...they also take some off the fan shroud to pull more air through the fan and radiator...
You can stand behind a Butler equipped van and feel the air moving all the way to the back doors....
They are not only trying to cool the van motor, but also cool the entire van all the way back.... (transmission, fuel pump....everything)
I discovered it this Summer.....I had a vibration start to develop on one of my vans and we found the flex fan was starting to wear out (bearing on the fan)....
So, we did a replacement with a temporary fan to run the van...but not the truckmount....
I was told I could have used that different fan...and it would have cooled the van motor just fine....but Butler did not want me running the Butler unit with that fan...
They take their R&D serious I am finding to make sure the van is protected while doing the cleaning and you get a lot of durability out of them.
