Rockin it with Encap
20,000 sq/ft to clean. We sent a 4-man crew and two gurls vacuuming. We finished it in 3.5 hours and the facilities manager was thrilled with the results. We've been cleaning it for 10 years and and 4-years ago switched them over to Encap. They like the results, enjoy the fast drying so the can get their tables setup and ready for the next event.
Blue Monarch
Dirk Wingrove
Encap is the only way to go in rooms like that IMO. Hard to argue with results.
I'd have to see what you're doing wrong. Encap on CGD should "look" better than HWE.
While I understand that doesn't seem possible, it is. We cleaned an accounting office last Friday that asked us not to use "the hoses machine" because the other machine we use (Cimex) looks so much better. :eekk:
How many RTU gallons of solution did you go thru?
James lets just say "a SHIT load". J/k I can figure it out for you tomorrow if you really want to know.
Pee.S. A shit load is a little more than "a hell of a lot". :winky:
Way way?
It may look better to
Reactions: Mike Draper
Donwand
Brian
What kind of juice do you use? Most of the time I use my cimex on CGD not lovin the results compared to HWE.
We used some of Rick's new Citrus Releasit. The majority is a secret sauce Jim Pemberton makes up exclusively for us, Encapuclean DS2. :winky:
ok so maybe you can get it at other Interlinks? I don't know, I only buy it from Jim. :cool:
I can tell exactly to which Kenny's song R.C. was listening to, by looking at the end result of each section.
Unfortunately Chavez Resto may not be able to afford Bobby D. and boy is that reflected.
As a result and from a pure technical accomplishment stand, they may be forever doomed to keep on knock, knock, knocking on heaven's door:
Russ T.
Russ Terhaar
From my experience, the APPEARANCE is better on CGD with encap. It's faster, quieter, cheaper, and flat out enjoyable to run the Cimex with encap. Doors locked too so nobody be creepin' on me at night!
You only enjoy it because it's less work...:stir: I have no problem with people using encap in it's intended purpose.... It's the guys who use it in daycare's, preschool & elementary schools, and residential with kids present that's what chaps my ass, really grinds my gears... :lol:
it looks better. I can't explain why but I've done side by side using Flex with citrus and a high heat Butler and while I know the HWE side removed the soil. The Encap side looked far cleaner.
Clients hire you because A) they expect improved appearance B) they want to know it is clean. In the case of most commercial work improved appearance ranks higher than soil removal.
When soil removal is more important we will Zipper it. Even in those cases we offer them the option of Encap.It's their property to maintain, we give them our opinion and their options. They don't always listen to us but in the end we make money either way.
Reactions: Donwand
rick imby
Rick
So Mr Chavez---The guy in the picture doesn't look short enough or old enough to be you but if it was you I would guess they have finally found the job for you ----takin out the trash---
Thanks Damon!
However
sometimes we get so busy it ends up being "I've seen better organized shit fights from the monkey's at the zoo". :biggrin:
BUT its my fault when that happens. Just as Steve Toburen says "The Fish Rots From The Head Down". :errf:
I'm not doing my job to make it easier to do the right thing or enforcing policy & procedure.
T
thecleaningdude
A vast majority of business owners would love to have that problem :)
Thanks Damon!
However
