- Oct 9, 2006
- 64,833
- Name
- Rico Suave
I think 20 until testing and a protocol was written then reduced to 15-Drizair HEPA 500's.
Dan I spoke with the guys and it is the drywall joint that caused it. The mold has hard time jumping the capillary break, so you get that sharp edge.Wow! What caused the sharply defined horizontal limit?
When you hang drywall you start at the top ceiling edge and cut the lower piece to fit to the floor, so the cut piece is always at the bottom since it's rough edge will be below the base trim and will not show.i also wonder if maybe that was the joint line for the drywall but it doesn't look quite high enough. ??
Thanks Bob. That makes sense.When you hang drywall you start at the top ceiling edge and cut the lower piece to fit to the floor, so the cut piece is always at the bottom since it's rough edge will be below the base trim and will not show.
Mix up a little Bleach and water mixture and it will be good as new.That would just wipe right off.........![]()
Best place for that tool.I remember one of my pops friends gave him a wallpaper poker/roller that you'd use to dry wallpaper basically making tiny pinholes to let the moisture escape.. I've only see the tool buy never used it.. I think it rusted out from the dust and we tossed it..
