Quick Connects - Which one leads?
Tony Wilson
Tony Wilson
I have always had the female pointed toward the wand. But have also seen guys do the opposite and go male end toward wand. Any advantage to either or?
We have always had the female on the solution line and connect to the male on the tools. Female at the unit receiving the male end from the solution line.
When we buy Butlers we switch them so the match our Prochem's.
:biggrin:
Reactions: Tony Wilson
Able 1
Keith
It's not mine btw..
For me, it's male on my tools.. Heat and dropping it on concrete from the second floor is the biggest killer for a females.. You can drag her around all day!
Some prefer the female on the tool so that the each hose connection has the female facing toward the truck.
The reason that they do this is that if you have the female facing the wand, and if you pull it against a concrete curb or step, you can possibly cause the couplings to disconnect at a time when you machine is not under pressure, which can cause the cleaner to think his machine isn't working (an obvious thing that's overlooked by anxiety ridden newbies), and even once its discovered, its a pain to reconnect the disconnected hose once its under pressure.
I still prefer it the way the majority here have stated it with the male on the tool.
But I do keep an eye on couplers by steps and curbs.
I can see that Jim. I've done it more than a time or two. It doesn't happen often but if you drag a hose, its very possible should it get hung up on something.
KevinD
Kevin Dumas
All my cleaning systems that I have owned are plumbed the same.
All lead lines get a female on each end.
This allows you to use less expensive male connectors on each tool and also eliminates the couplers from disconnecting if you happen to drag them across something.
Cleantechsk
Dustin
I use stainless steel male on my solution.
Dont have to worry about snow getting in :)
my SS have been freaking bullet proof for the abuse they take
Reactions: Steve Smith
Its a personal preference!
I think you can do it either way.....as long as you don't mind being WRONG! :winky:
Reactions: Willy P
Done it both ways. I've never had a male go bad from dragging. It's incredibly sandy here and I just got tired of cleaning out the females. All the females do have to be the same brand or your main tool will change the male and it won't work on the others. As far as connectors coming apart my main line is 150'.
Gene
What's that?!? :rockon:
Like @GeneMiller said, I have to worry more about sand, but I hand coil my 100' solution line.. As in life, you bring the SS females to the males on the tool...:lol:
Art Kelley
All the tools I buy have the wrong end on and I have to put a female end on. So yes, that does get expensive. And you aren't supposed to drag a female.
Brian H
Brian H
And if you blow that lead line, you can't throw another spare onto it. I worked for a company once that did it that way and after having to run out a new "lead pressure line" a few times, I switched it so that all lines were exactly the same and could be used interchangeably.
