Tony Wilson
- Sep 17, 2015
- 221
- Name
- Tony Wilson
I have always had the female pointed toward the wand. But have also seen guys do the opposite and go male end toward wand. Any advantage to either or?
Not even a little?Never drag hoses.
Never drag hoses.
Some prefer the female on the tool so that the each hose connection has the female facing toward the truck.
The reason that they do this is that if you have the female facing the wand, and if you pull it against a concrete curb or step, you can possibly cause the couplings to disconnect at a time when you machine is not under pressure, which can cause the cleaner to think his machine isn't working (an obvious thing that's overlooked by anxiety ridden newbies), and even once its discovered, its a pain to reconnect the disconnected hose once its under pressure.
I still prefer it the way the majority here have stated it with the male on the tool.
But I do keep an eye on couplers by steps and curbs.
I use stainless steel male on my solution.
Dont have to worry about snow getting in
my SS have been freaking bullet proof for the abuse they take
All lead lines get a female on each end.
This allows you to use less expensive male connectors on each tool and also eliminates the couplers from disconnecting if you happen to drag them across something.
Saiger" data-source="post: 4394334" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Not anymore!Of course being a Butler owner for years....
All my cleaning systems that I have owned are plumbed the same.
Not anymore!
They fired the guy that had been putting them on backwards. Nobody checked in all these years until yesterday.![]()
