Art Kelley
- May 19, 2007
- 4,200
- Name
- Rainbow Carpet And Upholstery Cleaning
It is, isn't it. Like Reagan said, "It's morning in America." On CGD, what the hell is the difference?awesome!!
What did you order, 360i?This is exactly one of the reasons I am excited to get my Rotovac....which is supposed to come today!!
It is really going to open up a whole new realm of possibilities.
You won't be sorry performance wise. I believe the 360i is the lightest rotary extractor out there at, I believe, 39 lbs, though it can still be a bit tiring with enough up and down steps. The results, however, are worth the effort. Congratulation on your new tool!Yes...I need the lightness of the 360i because of my back.![]()
12" pads will work (either red or white) and you can sometimes get them cheap on sale, but the 13" work the best as they go to the wall. I have found 13" pads for $1.55 each at webstaurantstore.com. Bonnets are 13" also.what size bonnets/pads do you use for the RVi?
15?
Motor doesn't bog or heat up at all no matter how many hours I run it. I carry a spare 360i in the back of the van because I rely on it every day, but I have only had to use the spare a couple of times because the frame can break at the welds, but the motor has never failed. I changed out the brushes after 2000 hours on my main unit.Did the (small) motor on the 360i bog at all as the carpet dried?
Art have you tried an XL, or see any reason to?Motor doesn't bog or heat up at all no matter how many hours I run it. I carry a spare 360i in the back of the van because I rely on it every day, but I have only had to use the spare a couple of times because the frame can break at the welds, but the motor has never failed. I changed out the brushes after 2000 hours on my main unit.
I wouldn't get one for the same reason I wouldn't get a Hoss or a Mytee Trex: they can't do stairs which I encounter on most of my jobs and the 360i knocks them out of the ballpark no matter how bad they are. There really is a wow factor when you can renew a badly matted and trashed staircase with the 360i; like nothing I have ever used.Art have you tried an XL, or see any reason to?
Try it yourself. You have a 360i?I really need to see a videoof someone using a 360i on a staircase..
I have that head, and don't care much for it. The pressure spinning things work real well for me on tile and grout.Thank you! I want to eventually get the tile and grout head as well since we clean a lot of it.![]()
I have a GoPro I'll strap to my head and make one.
What don't you like about it? And which one do you have? One of them has a vacuum ring around ot?I have that head, and don't care much for it. The pressure spinning things work real well for me on tile and grout.
I know there is a stair head you can get for it, but there's no way you can clean the risers with the 360...that would be the biggest issue I would think.I really need to see a videoof someone using a 360i on a staircase..
The 360i isn't heavy enough for tile and grout. I suppose it's okay for those small squares in public bathrooms, but not so good for larger tile with deeper grout lines.What don't you like about it? And which one do you have? One of them has a vacuum ring around ot?
, but if it won't work well on dirtier tile jobs, its not worth getting as it is easy to pull out our turbo for sure. I was hoping the agitation of the 360 would be good on other jobs as well.....oh well! I guess I will hold off on that one. Thank you for the "heads" up! Hahaha!
