This OG head makes sense, the 12 does not.
Agreed!Call me @Desk Jockey , but IMHO it's too much work to take the shroud off to switch to use the smaller head
Better outcome. And FWIW, the edges come out looking outstanding with the standard head.when the normal head does it faster and same outcome.....
I question the comparison. Though at 59+ it really doesn't matter any longer.Same reason I don't like threesomes...... Double the effort for the same outcome.......![]()
Prespray the stairs......use a scrub brush for the nose and use your stair tool.
That rotovac looks too cumbersome to use.
10 minutes?
come on.
you still need to wand or hand tool all the edges and risers, right?
Why? It takes five to eight minutes to do set of steps.I hope you guys are getting $150 for a staircase
I've timed it many times, that's going slow with the RV. Then yes, a quick dry vac with the wand going down, and a quick steam up the riser. Effortwise, on a trashed stairway, it's easier than hand scrubbing and slowly
wanding to still not get the results of rotary cleanin. Same as traffic lanes in a room; if you tried to hand scrub and wand you would have no where then results of a RE. You know that. And stairs are often the worst traffic lanes in a house.
Am I the only one that uses an old fashioned internal jet upholstery tool to do stairs? I haven't found anything faster or that does as good a job.
