I'm telling you...
Zee
SoCal jungle
This really works:
1 gallon warm or hot water
2 scoops of Procyon powder
1 to 2 ounce of Trashed Green
1 to 2 ounce of 40 volume
I didn't have the CRB nor the Dwellpro.... And it is not truckmount accessible.
So just padding.... With the 360XL.
The whole place looked like this. Two bedrooms, living room, dining room and 2 weird long hallways.
Thick white carpet...corn rows every inch.
They keep a plastic chair mat there where it's clean.
Zee
SoCal jungle
I clean this place every 6 months for the past 8 years. It gets trashed the same way every time.
Usually takes twice as much time as a normal cleaning job would. Carpet is very dense and thick...so much so that the vacuum cleaners get on their own track regardless where you want to push them.
IL
That's pretty suprising...
Those bonnets must have been dirty after a minute of scrubbing!
Maybe it's the sticky residue do to HWE and poor rinsing? At least now it'll be a dry residue.......:stir:
Nice work Zee!
Reactions: Zee
Zee
SoCal jungle
I stopped by at a regular custy to check how everything is.
Old German guy with a "fery sctronk akksent..ja?"
He's got an 8 year old polyhorror carpet that I have cleaned over the years with every juice we talk about. Also tried multiple methods. (porty with wand, porty with rv360xl, truckmount with high heat high flow wand, Orbot padding with various juices... You get the point)
It's the type of plastic junk that grabs your vacuum cleaner or crb and starts pulling it in whatever direction the carpet lays. Of course it has all the pile reversal issues you can have, so you'll be dancing/chasing your machines.
That last time, I cleaned it -almost four months ago- with the above mentioned "secret sauce recipe". Padded it with multiple different pads.
It usually looks pretty bad in about 6 months. This time (today) it looked great. Unbelievable how well it's holding up.
Zee
SoCal jungle
Will that mix work without the 40 prox when cleaning a non white carpet or to clean a solid blue carpet? jz.
Trashed Green already has a good amount of peroxide in it...so if you want to leave out the peroxide, you will only be using Procyon..
But I don't think peroxide would be a problem for the blue carpet. (unless it's a protein fiber)
