Mark, how does the zipper wand compare to the cx-15?
As Mikey posted....
And will definitely say faster...
The new Zipper SS Spinner is pretty cool though...but with spinners you have to run the pressure higher (still not taking more water really though) and you are going to find that you will probably use the regular Zipper the most....
We use the Zipper about 80% of our cleaning....including residential....but there are times we will still grab a wand (still need a good cleaning wand no matter what) and then for super trashed, we will use an RE (we use Rotovac 360 XL's) .
Let's just say...there are sometimes what you think is going to be the best tool at the moment for a carpet...well...you might need to change up your hammer....
The Zipper will sometimes still need pre agitation and we use the small 10 inch
CRB machines (you can get a super sweet deal from Rick Gelanis at
Excellent Supply @encapman)
The Spinner is really your go to tool for Greasy Grimy type jobs, so if you were mainly doing really super trashed restaurant work, that could be your go to unit.
I recommend the regular Zipper as the best all around tool if buying a zipper.
With either the Regular Zipper or the Super Spinner, the advantage is it cleans both directions at the same time...
Also, with a spinner on carpet, the crop circles seem to start at the beginning when pulling the trigger...the SS Zipper moves easy and also if you stay on the trigger, you don't have to wait for the spinners to wind up...and really avoids the possible crop circles....
I think that is maybe a bit of the problem with the CX 15...people pull the trigger and are not able to get moving smooth or quick enough to avoid some crop circle problems...
I have only used the CX 15 a couple times and only at trade shows, so my experience I do no have enough hands on other than those few times to give you more info...
But, I really do love the Zipper wands....and the SS Spinner is a cool specialty tool in my opinion too....and built to last!
