Viagra for your Battery
dgardner
Dan Gardner
I've got the big one (XP-10), wouldn't be without it. Besides jumping a dead battery, it has USB jacks for charging phones and such, a 19V jack that will run my laptop for several hours, and a 12V jack for accessories, not to mention a built-in flashlight. You can charge it from a 120V outlet or 12V vehicle power jack. Highly recommended.
http://www.amazon.com/Antigravity-Batteries-AG-XP-10-USB/dp/B00MQ5Z5F2/
clean image
Carl Maddock
Costco one is good, for 99$ schulster includes 120 inverter power...
Scott S.
Scott
i have my rage tm setup with the same battery as the van and a set of 12ft jumper cables, so i can jump off the tm battery or switch them if needed.
Reactions: dgardner
I carry long jumper cables. No way that thing starts my diesel so why bother. I change the box truck batteries every 6 years or so.
Gene
Mike Draper
Gene
you'd be surprised. I sure was. Last winter my friend started his diesel pickup with one of those. They are unbelievable.
Mikey turned me on to them a couple of years back.
Now we carry noco genius boost packs as they have more robust jumper leads that don't fail.
I generally replace a battery based on time. I've only been caught once so far. My pickup didn't even give a warning and died. Not even a click when I turned the key. I'll check into it if you swear it will turn over a diesel. I love new gadgets.
Gene
Reactions: Scott S.
