im supposed to pull the bypass orifice monthly. I only pulled it a couple times on my previous machine, all near the end. I had the magnet and although many don't believe they work the proof is in the pudding as they say. So today the machine shut down because it hit 280. I had to keep the bypass open to keep it from spiking but it was the easiest solution. I popped the nut off and tried to get the orifice out. No chance. Frozen so bad the the Allen wrench was twisting. Not a cheap piece of junk either. Nice tight fit and yep, I turned it hard enough to strip the little bolt. Didn't have a wire with me small enough to clear it. After a 12 hr day I'm to spent to get out the extractor.
Moral, don't wait until 800 hrs to pull the orifice out it will be frozen solid.
Gene
Gene
