The new rig
Chris A
Finally getting a second to upload some pics. Loving the heat and vac of the 1200 SE compared to my old CDS. I was even spot cleaning some carpet today while upholstery cleaning and I left the machine on low. Plenty of vac at 150 feet and 200 degrees on 06 flow
All fits out the side door ala CDS
Best Lining job I have ever seen!
Chocked full of shit!
06 flow Ti wand heavy trigger 65 degrees
mirf
David Mirfin
Very nice machine. Maybe in the spring we will make a move.
Reactions: Chris A
Chris A
Only way to be able to use the hose access in the step. She got plenty o suck
Beautiful install and would like to know the benefits of spraying the liner so high.
Again very clean, congrats!! Enjoy it!!
Reactions: Chris A
Brian H
Brian H
Nice rig Chris, congratulations!! You are going to need a couple more soon to support that growing family of yours!!
Reactions: Chris A
Chris A
I actually didn't spec that, the liner guy had enough left over and went up as high as he could at no charge to me. I wasn't gonna complain!
Reactions: dealtimeman
Chris A
Thanks Brian, Kevin and I are going to split up starting in March which will give us a ton more capacity abs allow me to be home more. The 60 hour weeks are no fun with a little one (or two) at home
Reactions: Brian H
Congratulations. You'll love the machine.
Not quite. I have the 1200 (old- 2014) all you need is to move the box back and you can avoid the 90 degrees and keep the step access. That's what we did in my install.
Yes, they do have plenty of suck, but what the hack SS, move the box a little back, he'll still have easy access to the box and it will increase suction.
How much?
I don't know.
Reactions: Chris A
Chris A
Good idea, I'll have to look and see if I have enough room to do that
Chris A
The odds of me using that pork hole are slim to none anyway I ought to just get rid of the elbow
I think in the new ones it is welded onto the frame which will make it a bit of a hassle to move.
Be a lot easier if that is how they did it to begin with.
Reactions: Chris A
Lift looks a little low to me but other than that nice rig. Can't you organize that pile better. To much clutter behind a new rig.
Chris A
I don't normally carry my portable so I wasn't about to spend a bunch of time making sure it was organized perfect. Lift is set at 14"
Since we're nit picking, wtf is up with the double female on the wand? And no jet extenders? :lol:
Chris A
Those double male and double female qds have saved my ass a number of times even I pull out a seldom used tool (giggity) and realize its got the wrong connector on it! Sadly I realized the portable wand was wrong 5 years ago but the double female qd has become a permanent piece. And fook jet extenders...
I still think your a good egg, even though you have your quirks... The 2 jets closest to the tube doesn't hit it? The 1 PCTI I bought from a guy the middle jets would hit it...
I see what @hogjowl means when he said @Desk Jockey pissed on his balls...:eekk:
Chris A
No in fact it seems to clean way more even than my Ti with Extenders, I'm regressing technology wise
