Customer brought in a HM Titan 575 with these symptoms.
1. Started fine, but quit running after a couple of minutes.
We checked the fuel pressure and quantity of fuel delivered, and it was OK.
We tested the inline filter for fuel flow.
We tested the fuel solenoid in the carburetor for intermittent operation.
(when we pulled the solenoid off the carb it looked clean with no gas varnish)
Customer checked with Kubota on a new carb and found out it was $600.
We took off carb and proceeded to clean it out.
Cleaned the main jet and low speed jet, but they were not causing the problem.
Float was OK and needle moved up & down properly.
What next ? ?
What is your guess as to the problem?
We did fix it.
What next ? ?
We did fix it.
