Cobb's Dynachem Citra Green Pre Spray Give A Way
Cobb's Dynachem Citra Green Pre-Spray Giveaway!
Battle of the Green Pre Sprays continues on MB with Larry Cobb's entry into the game.
Six winners will take home a gallon each of Citra Green
Citra Green Prespray 16/1
Our new 16-1 concentration Prespray!
Aggressive liquid uses Biorenewable Citrus solvent, in addition to new Biorenewable Surfactant System to attack the widest variety of soils.
Dilutes 16 to 1 with hot water.
Aggressive Solution for Poly/Olefin carpets.
24 oz./Inline Sprayer - pH-10 (8.0 after rinse).
8 oz./Gallon in Sprayer - Portable Extractors
This product has a BioRenewable Index of 75.
This is the percentage of product that is grown from a plant or tree.
Also, this new surfactant is replacing solvents in a variety of cleaning applications,
due to its huge degree of Hansen solubility,
which dissolves soils that previously required butyl and chlorinated solvents.
Ideal for those oil-loving new fibers like SmartStrand, and fine denier polys.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=65&products_id=5344
Hansen?
Like the all natural soda?
Larry why don't we let one of the 6 winners have a chance at winning one of your UV flashlights?
We'll have a contest and the one who can best photoshop your face onto Jane Fonda's body for instance...
Zee
Hansen?
I have to wonder how the chem manufacturers will make a profuct that stands out if they all have to use similar, if not the same, raw materials..
Zee
Is this product something that could be used as a padding only juice?
It doesn't sound like it and the words are indicating rinsing...but I thought I'd ask. Just in case there is a very diluted application that could be acceptable to just pad without rinsing.
D
dgardner
Ph of 10 if not rinsed, contains surfactants and citrus solvent - doesn't sound like something I would leave in the carpet without rinsing. The potential for rapid resoiling seems high.
@Larry Cobb ?
The surfactant rinses well enough that it would make a good bonnet cleaner.
Some residue from the Citrus solvent , but the emulsification of the surfactant with the powder builder should handle it.
Reactions: dgardner
Zee
So what you're saying is, that it would be okay to use it as a bonnet cleaner? At what dilution ration would you recommend doing that? Have you guys done any testing like that?
A.J.
A.J. Hodges
Hey larry thanks for the flash light! My first ever xmas gift lol
Larry is it wise for a man in your position to recommend a machine you have not used, let alone seen?
I have talked to a man I trust, who has used it a lot,
and seen his cleaning video.
I think Paul Brown has also tried the equipment
and aided in its development.
