The perfect wand....
TConway
Thomas Conway
I think the perfect wand would be a swivel with the ergo handle on the Prochem TI Ergo wand.
@TConway? Is this possible?
What is the perfect wand?
One that has sooo much suck you cant move it? Or one the moves as lightly as a vacuum cleaner?
One that swivels? Or one that is Fixed?
One that is super light? Or one that is heavy?
2.0 or 1.5?
Fixed jets and flow? Or one that is adjustable in shear and flow?
A steam throwing beast? Or one that puts the steam in the carpet?
One that sucks out as much water as possible? Or one the flushes more but leaves carpet cleaner but, a little wetter?
I do not own a super high heat super high vac TM, I did this carpet over the weekend. It is a poly fiber carpet, I used Prozyme (not a very powerful PS) no agitation, just spray and clean. I had to make a quick adjustment to our wand and the results were great. We are tryin to answer all the above questions above to try and make a great wand.
A lot of things are out of the Wand's hands and the machine's responsibility. How much suck and heat.
I was thinking earlier how when I went from a 3.3 blower to a 4.5, 4.7 now a 4.8 the level of cleaning goes up. The only thing is the 405 with a 4.7 blower and a unglided quad or Ti wand would break your wrists and disengage carpet.
So the glides are a must making any bigger blower machine more user friendly.
Heck my 4.8 blower with 12 inch hybrid is hard to push but its not titanium.
So the weight of the wand plays a difference to.
My PC Ti wand with a holed glide is amazing for most applications.
Reactions: Kellie Hiler
a good wand is a balanced wand. doesn't matter too much if it light or heavy, can you easily move it forward and back with out shoving the hell out of it? can you use it for 4 hours without being fatigued by it? I have a 2 inch, four jet s-bend wand that won't glide worth shit. I have a cheaper 1 1/2 incher with 2 jets that glides smooth with no effort. one of my favorites is an old steamway wand with a heat shield and a single flood jet. puts the hot water closer to the carpet where you need it. I don't seem to see any flood jetted wands around anymore, wonder why? a lot of the multi-jetted wands clean well on cgd but leave streaks on deep pile carpets because the jets are too close to the pile. Wouldn't flood jets be better? How about a telescopic wand that can convert into a stair tool or a full size wand so we don't have to go back to truck to change tools. How about removable end pieces so we can change to a crevice tool or a hard surface tool? One multi-wand that does everything instead of several pieces of stainless steel rattling around in the truck.
Scott S.
Scott
Please make that video starting with how to open the box. And don't have your wife standing behind you telling you what to do.
Jimmy, just because your wife tells you what to do doesn't mean mine tells me what to do.
K
Kellie Hiler
One that stays on the truck while you Zipper and RE. :rockon:
There will always be a situation where I need a wand. Here in Colorado we seem to have a lot of bathrooms with carpet in them. I usually clean them with a stair tool, but as you can imagine it kills my back. That swivel wand would be perfect for the jobs that are just a little too tight for the other tools.
A week ago, I told myself I was going to just take the wand off the truck so I don't do something stupid...like "oh this is just a quick wand job" and mess up my back. But the reality is, a wand should always be on the truck.
Scott S.
Scott
2.0 or 1.5?
cant wait to try out your new wand in atlanta
I like to use this to clean the bathroom carpets......
Nah, but seriously tell them to tear that sh!t out unless all the males sit down to pee....... I ain't getting up close and personal with some peepee......
K
Kellie Hiler
That's a pretty cool wand, I've never seen one like that!
And yeah....it sucks trying to clean around a toilet with a stair wand without touching the toilet...:eekk:
K
Kellie Hiler
It seems that a lot of the builders out here cheaped out...it was cheaper and easier to go with continuos carpet. It's really disturbing how often we run across it.
We need a specialty tool for every single issue we face.
A variety of wands starting from 2" all the way to 16"
Specialty wand to clean under the door stop.
A specialty stair tool for the stairs 90 degree angle and another one for the bull nose.
A few Rotary vacuums of different sizes and heads.
A large Crb and a 10" crb for the stairs and the 3" CRB to clean the Zipper.
A few zippers.
And mostly a trailer to carry it all and road a map of how to find it in the damn van.
Spurlington
Spurlino
Id rather unscrew the door stop or go at it at a different angle than to run out to the truck for another wand. Unless you have a bucket of wand heads you bring in to change out for every situation. Kinda like the tile tools.
John Olson
John Olson
Kellie the perfect wand is the one that fits YOU. What one person likes the next person will hate. All these "ideas" sound great until someone has to actually try and make them. I wish you were closer and I could just let you take a couple out to try. You might find the Prochem Quad with a glide is the one for you or a standard CMP 12" or maybe the Prochem Ergo TI. No matter what one you get Kellie make sure you try it first. Don't buy it on hype (swivels are a weak point always will be on anything) or on price but buy it because it fits
She has a Ergo PCTI Big John..... Like most women, she makes due with the wand she has on hand..............:yawn:
