Who knows this vacuum?
Talked to a 36 year vet today
He use to run six truckmount crew.
Now he rocks it solo out of a minivan, a 150 Ninja, a 175 and a mountain of Polysorb loopy bonnets.
I could tell with out a doubt he does a great job.
This is his vacuum...
Reactions: Russ T.
POS PowrFlite vacuum........... Had like 10 of those back in the 1990's...... ;)
Just tossed the last one a few years ago..... Took up too much wasted space.... lol
Reactions: Papa John
La Canada, Ca
La Canada Carpet Cleaning
I used to run them, the ports get plugged up all the time. Pretty powerful vac. The flat belt didn't last very long either
KevinD
Binghamton,New York
Kevin Dumas
I have a couple I still use.
Only problem I ever had was the bar in the brush roll coming loose from the groove on several.
Could have been a bad batch of rollers.
I had a blue plastic a Royal from clean freak had the same setup on the bottom worked great til the rubber melted the plastic.
TConway
Thomas Conway
Power Flite vac like everbody has said, I use to use them back when I was 20 years old and my first cleaning company, we did a bonnet system and used a power flite vac it was pretty powerful and light weight.
Um we might say there junk......but that thing looks like it has been around for a while LOL
Boca Raton
Power flight was my first. Didn't last very long before the motor started screaming. I threw it away. Worked fine up until then. I even had the attachment that you could show your customers the dirt with. I might still have that some where
adamh
Nampa Idaho
Adam Hale
I don't think I would clean anymore if I had to go back to a porty. Walmart greeter sounds better than using a porty again.
TConway
Thomas Conway
YES that is the same thing I had hooked on the back of the vac.
My supplier at the time told me " This is the soil analysis test" You do this and you can sell vacuums too!! Oh being 20 years old and gullible
