Cobbs unit truckmount?
Lonnie
The owner of Easy does not want his products mentioned here on MB so I removed portions of your post
Sorry.
Lonny
Ouch, kinda makes a comparison fairly impossible.
Lonny
45 Blower, 20-25 hp motor, easy to work on, stainless heat exchanger, no propane or kero.
Can be mentioned on the board.
jack zerkie
I have the 2045 unit for over 5 years no problems. I had other units at double the price, built by the big guys. Cobb was the best pick. The units are simple and easy to use. Just ask me oh yea I just turned 74 on sat, so even with oldtimers I can clean without problems thanks to Cobb. jz.
T
Todd Millar
Wow !! 74 seriously ? Thats awesome :biggrin:
R
Ralph Pastorelli
Both those Texas builders make a simple and reliable machine without the cost of the big name brands so just call them both for a demo and compare the units. I would also consider a Judson if simple is what you are looking for.
A.J.
A.J. Hodges
I've had cobbs one for a few months. The simplicity is very relaxing. It will need another muffler, Get a wand bypass otherwise you always have "Oh god am i overheating" in the back of your mind when you need to move something. It's hits 250 fast when you set it down. My only Issue ive had is they had a bad bath of hoses there were over crimmed on the ends and almost burst like right a way. Had bubbles on the ends. Easy fix. Other than that the Kohler either gets to much fuel or not enough air so I've been running without an air filter for a little while...
R
rjwood
It looks like I'm on the verge of purchasing one of Larry Cobb's machines. I've been talking to Larry and Marie getting answers to questions.
Reactions: Art Kelley
If you want a bullet proof machine buy the aluminum 24 hp Honda with a number 4 mr blower.
We have many on the property management side with over 5000 hours on them.
DO NOT BUY THAT ONE IN YOUR LINK!!!! Buy the aluminum version that is a true dynachem unit not a rebranded Wichita Falls unit.
A dynachem unit need only one thing and that is common sense. So it is not for everyone.
R
rjwood
Would you also choose the 24 hp Honda unit over this one?
jack zerkie
I forgot to say my unit has the mytee roto mold recovery tank only 80 -90 gallons, but wow easy to keep clean and no smell.Mine mount behind the front seats or right side looking in. The noise is very loud from the engine. I went to a private muffler shop and he added another muffler under the right side of the van a bullet style like Cobb uses with the factory set up much quieter for about $200. parts and install and well worth it. jz.
Spurlington
Spurlino
pics?
Reactions: dgardner
For your Promaster?
Sweet.
Have I told you all how happy I am with my Transit?
Yes the Honda is just what you need to push the 4mr and General pump. This is a no frills just simple unit that produces good heat and suction.
I would demand a clean out port on the front of unit for waste tank clean out and I would have the put a pump clutch on the unit for ease of use during extraction.
Spurlington
Spurlino
Spurlington
Spurlino
I gotta tell ya .. Im quite impressed that youre slingin furniture and scrubbing carpet at your age. I just turned 48 and there are days where Im looking for a cane at the end of my day. Im curious as to what you look like. I would love to move along as long as I can but cant imagine Id have the strength. Do clean with a helper?
Reactions: Kellie Hiler
